Who Makes the Best Portable Waste Tank for RVs?
IF YOU’RE TIRED of breaking camp just to visit the dump station, it’s time to invest in a portable RV waste holding tank. But with multiple brands, capacities, and feature sets on the market, picking the right one isn’t always straightforward. While other guides cover what a camper tote tank is and how to dump a black water tank, we’re here to help you compare the top four brands side by side — and find the best match for your rig.
The short answer: For most RV campers, the Camco Rhino is the best all-around portable waste tank, thanks to its ready-to-use kit, integrated tank rinser, and exterior storage options. But it’s not the only strong choice. Barker’s Blue Boy leads on raw capacity and rough-terrain performance, the upcoming Valterra Silverback brings modern monitoring with a fill-level window, and Thetford’s Titan series is the ergonomic pick with its AutoStop overflow gauge. The right tank for you comes down to your rig size, terrain, and how you plan to transport it.
Below, we break down sizing, standout features, and the mounting hardware you’ll need so you can choose with confidence.
  • Size Matters: A tank capacity equal to or slightly larger than your RV’s smallest holding tank (usually the black tank) helps you avoid multiple trips or unmanageable weight.
  • Feature-Driven Selection: Prioritize tanks based on your specific terrain and tech needs, such as pneumatic tires for gravel roads, integrated rinsers for easy cleaning, or level gauges to prevent messy overfills.
  • Transport & Storage: Towable models with hitch loops make it easier to transport to dump stations, and bumper or ladder mounts keep waste storage out of basement compartments.
Is the Largest Portable RV Waste Tank the Best?
The most common mistake is buying a tank that’s too small—leading to multiple trips to the dump station—or too large—so you can’t even move it once it’s full. Your portable RV waste holding tank should ideally have the same capacity, or slightly higher, as your RV’s smallest holding tank, which is usually the black tank.
  • For small travel trailers or weekend trips, a 21 to 25-gallon tank is usually sufficient.
  • Mid-sized trailers often find the 28-gallon size to be the sweet spot.
  • For larger rigs or families, a 36-gallon RV portable waste tank is often necessary.
Full-timers or those boondocking long-term might need even more capacity, but remember that water weighs roughly 8.3 pounds per gallon. When choosing one of the largest portable RV waste tanks, ensure it’s towable so you can use a secondary vehicle to get it to the dump station.
Who Makes the Best Portable RV Waste Tanks?
Obviously, the best portable waste tank for RV use depends on your needs, but our top three competitors are made by Camco, Barker, and Thetford.
Camco
The Camco Rhino portable RV waste tanks are widely regarded as some of the best options because they are made of blow-molded, UV-stabilized HDPE that resists the sun without leaking or cracking. Depending on where you shop, you’ll find several sizes available: 21, 28, 32, and 36-gallon capacities.
The smaller models boast two no-flat wheels, while the larger models upgrade to four-wheel configurations. Many are also sold as complete kits, coming with a short sewer hose, clear elbows, and a tow bar. They are also designed with an integrated tank rinser, an integrated hook for hanging on an RV ladder in transit, and additional grooves to help strap them in place.
Barker
Affectionately known as the “blue boy” totes, the Barker portable RV waste tanks offers similar variety. You’ll find several sizes: 16, 25, 30, 32, and 42-gallon capacities. Their largest portable RV waste tank is built for heavy loads, featuring pneumatic air-filled tires rather than plastic wheels.
The added maneuverability of a 4-wheel portable waste tank for RVs makes it easier to position under your RV outlet, thanks also to 360-degree rotating front wheels. It also features a built-in pull handle with a tow loop on top, making it easy to slip over a hitch ball to pull to the dump station.
Valterra
Image by Valterra
Set to launch May 1st, 2026, Valterra’s new Silverback portable RV waste tanks are “state of the art.” They’ve innovated to deliver an improved portable holding tank experience. That starts with a Clear View window to prevent you from ever overfilling again. For cleaning, an integrated 360-degree sprayer serves a similar function to an RV black tank flush.
The four-wheel configuration with its “Tow-N-Pull” handle makes it easy to maneuver, even when full. And the tow loop at the top fits multiple hitch ball sizes. Plus, they added a directional vent to reduce smells and a central handle to make lifting the tank easier.
Thetford
The best Thetford portable RV waste tanks are known for their ergonomics. Many include a large handle and an AutoStop level gauge to prevent overfilling. Their Titan series tote tanks are arguably their most popular, available in two and four-wheel configurations. They also offer multiple sizes: 12, 21, 27, and 35-gallon capacities.
Portable RV Waste Tank Comparison
Here’s a side-by-side look at the top four brands for 2026.
Brand / ModelCapacities (gal)WheelsStandout FeatureBest For
Camco Rhino
★ Best Overall
21, 28, 32, 362 no-flat (small models)
4-wheel (large models)
All-in-one kit with hose, elbows, tow bar & integrated tank rinserCampers who want a ready-to-use package with easy exterior storage (ladder hook & strap grooves).
Barker Blue Boy
Best Capacity & Terrain
16, 25, 30, 32, 42Pneumatic air-filled tires (large models)
360° rotating front wheels
Largest capacity on the market (42 gal) with pneumatic tires for rough terrainLarge families, boondockers, and anyone towing over gravel or uneven ground.
Valterra Silverback
Most Innovative
TBA (launches May 1, 2026)4-wheel with “Tow-N-Pull” handleClear View fill window, integrated 360° sprayer, & directional ventTech-forward RVers who want real-time fill monitoring and easier cleaning.
Thetford Titan
Best Ergonomics
12, 21, 27, 352-wheel and 4-wheel configurationsAutoStop level gauge prevents overfillingCampers who prioritize overflow protection and comfortable handling.
💡 Sizing tip: Match your tank to your RV’s smallest holding tank (usually the black tank). Water weighs roughly 8.3 pounds per gallon — a full 42-gallon tank tops 348 pounds, so make sure larger tanks are towable.
Which Portable Holding Tank Should You Choose?
Deciding on the best portable RV waste tank depends largely on your rig’s capacity and how you plan to transport the tank to the dump station. Each major brand offers specific advantages tailored to different types of campers.
If you want a complete, ready-to-use kit with integrated features…
Choose the Camco Rhino. These tanks are ideal for those who want a one-stop shop, as they often include the necessary hoses and fittings. They are the best choice if you plan to store your tank on the exterior of your rig, thanks to the integrated ladder hook and dedicated tie-down strap grooves. The built-in tank rinser also makes it a top pick for those who want an easy cleaning process without buying extra parts.
If you need the largest portable RV waste tank on the market, or if you frequently navigate rough terrain…
Choose the Barker Blue Boy. With a capacity reaching 42 gallons, Barker is the go-to for large families or long-term boondockers. The standout feature here is the pneumatic air-filled tires on larger models, which provide a much smoother tow over gravel or uneven dirt roads than standard plastic wheels. The 360-degree rotating front wheels also make it the most maneuverable option for heavy loads.
If you want the latest innovations and “state-of-the-art” monitoring…
Choose the Valterra Silverback. This is the best choice for Rvers who are tired of guessing their tank levels, as the Clear View window explicitly prevents overfilling. If you appreciate a deep clean, the integrated 360-degree sprayer acts like a built-in black tank flush. While these are set to launch May 1st, they are positioned as the most modern towable portable RV waste tanks available, featuring a universal tow loop that fits multiple hitch-ball sizes.
If you prioritize ergonomics and overflow protection…
Choose the Thetford Titan. Thetford is well-known for the AutoStop level gauge, which is a lifesaver for avoiding messes during the drainage process. Their Titan series is highly rated for its rugged build and large, comfortable handles, making it the best-rated RV portable waste tank for those who want a heavy-duty feel with simple, clean operation.
Buying Tip: Online vs Local
When searching for a portable RV waste tank nearby, there are benefits to buying in person. These oversized tanks often come with high shipping costs. Checking stock at a local RV retail specialist allows you to test the weight and wheel quality before you commit. Look for ready-to-use kits to ensure you have all the necessary parts from day one.
Must-Have Hardware: Mounting and Storage
Once you’ve picked your tank, you have to decide where to put it. You definitely don’t want an RV portable wastewater tank sitting in your pass through storage.
  • Bumper Mount: These metal brackets allow you to securely strap the portable waste tank to your 4-inch-square rear bumper.
  • Ladder Holder: Many Camco models come with an integrated hook, but you can also buy a dedicated waste tank carrier that hangs the empty tank off your rear ladder.
  • Undercarriage Storage: For a cleaner look, some use an undercarriage waste tank storage rack, though these are often custom-installed or rig-specific.
Check out these additional RV waste and plumbing resources:
Who gets your vote for the best portable RV waste tank? Let us know in the comments below!
The post Who Makes the Best Portable Waste Tank for RVs? appeared first on Camping World Blog.
This is a companion discussion topic for the original entry at https://blog.campingworld.com/gear-and-accessories/best-portable-waste-tank-for-rv/
