Where to Get Your RV Inspection
A seasonal RV inspection is the best way to catch minor issues before they require an expensive repair. But where can you take your RV to get inspected, and what’s covered in each type of service? At any Camping World Service Center, that’s where! We have two inspection services to choose from.
Our Courtesy RV Inspection is a great service to schedule at the beginning and end of your camping season. It provides a baseline check of your RV’s most critical maintenance areas.
Our 45-point inspection should be scheduled every 1-2 years. It’s also highly recommended if you’ve just purchased a used RV and want a better picture of its overall condition.
Let’s highlight the specific checks in each of these inspection services.
RV Inspection Services at a Glance
Want the quick-reference version before diving into the details? Here’s what each service covers, at a glance.
CategoryWhat Gets Checked
RV DetailsYear, manufacturer, make, and model
RoofVisible damage and sealant condition
Exterior SealantSealant condition around exterior doors and windows
TiresTire date code, tire wear, and sidewall damage
AwningTears, damage, and dry rot
45-Point Inspection
SystemWhat Gets Checked
ElectricalCircuits, batteries, converter, inverter, smoke detector, power cord
GeneratorOil level, muffler system, run test
PlumbingLeak test, water pump, toilet operation, drains, and tanks
LP GasLeak detection, hose condition, leak-down test
AppliancesStove, refrigerator, furnace, water heater, roof A/C
ExteriorTires, brakes, roof, seals, jacks, and lighting
Prefer the full detail? Both services are broken down below.
What Is Camping World’s Courtesy RV Inspection?
Camping World’s Courtesy RV Inspection is a free service available to anyone. The inspection takes about two hours and is often conducted by a service advisor or other service center personnel.
At the conclusion of the inspection, you’ll have a completed form with additional service recommendations. Any additional service that’s recommended after the inspection will require a separate appointment.
Here are the checks in our Courtesy RV Inspection:
  • RV Year, Manufacturer, Make, and Model
  • Roof Inspection for visible damage and sealant condition.
  • Exterior Sealant Inspection for the condition around exterior doors, windows, and seams.
  • Tire Inspection for date code, tire wear, and sidewall damage.
  • Awning Inspection for tears, damage, and dry rot.
What Is Camping World’s 45-Point Inspection?
Our 45-Point Inspection provides more detail, giving you a comprehensive health check for your RV. It’s a paid service available to anyone, and our certified RV technicians complete this inspection.
This inspection requires a full day and covers all RV systems, including electrical, plumbing, LP gas, generator(s), appliances, and the exterior. The technician then fills out a section with specific areas of concern that should be your highest priority for additional repairs.
Like the Courtesy Inspection, any further service will require a separate appointment. Here’s everything our technicians inspect:
Electrical
  • Hot skin test
  • 110-volt circuits
  • 12-volt circuits
  • House and engine batteries
  • TV antenna operation
  • Converter output
  • Converter charge
  • All exhaust fans
  • Smoke detector
  • Power cord
  • Inverter output
  • Microwave
Auxiliary Generator System
  • Oil level
  • Muffler system
  • Auto changeover operation
  • Run test
Plumbing
  • Leak test
  • Water pump operation
  • Toilet operation
  • City water intake and check valve
  • All drain cocks
  • Seal on termination cap
LP Gas System
  • LP leak detector test
  • LP hose(s) condition
  • LP leak-down test
Appliances
  • Stove/oven temp
  • Refrigerator operation
  • Furnace operation
  • Water heater operation
  • Roof A/C checks (output and return temps, heat strip, and filters)
Exterior
  • Breakaway switch operation
  • Brake control
  • Tire condition
  • Roof condition, including slideouts
  • Vent shroud condition
  • Entrance door gaskets
  • Window gaskets and crank handles
  • Tongue jack operation
  • Scissor jack operation
  • Antenna condition
  • Wiper blades
  • Shocks/springs
  • Exterior lighting
What If You Want to Do Your Own RV Maintenance?
Camping World also offers an orientation service to familiarize you with the essentials of RV ownership. It covers the operation of all appliances and accessories, how to dump holding tanks, and explains necessary maintenance and other general RV tips.
This service is designed to help you understand RV systems and troubleshoot DIY issues. You will also get tips on practicing preventive RV maintenance. Many service issues can be avoided by knowing your RV and following the manufacturer’s recommendations for proper use and care.
Call your local Camping World to schedule an RV orientation.
Is mobile RV inspection available?
At select locations, Camping World offers mobile RV inspections for these two services, as well as electrical, propane (LP gas), and appliance systems. A certified technician comes to you to complete these checks. Contact your local Camping World to confirm mobile inspection availability.
How much does an RV inspection cost?
Camping World’s Courtesy RV Inspection is a free service. The 45-Point Inspection is a paid service with pricing that varies by location. Mobile RV inspection pricing also varies by location and by which systems need to be checked. Contact your local Camping World for a specific quote, or see our full mobile RV repair cost guide for typical pricing patterns.
Should you get an RV inspection before buying a used RV?
A pre-purchase RV inspection is one of the best ways to avoid costly surprises with a used RV. The 45-Point inspection is a good fit because it covers all major systems (electrical, plumbing, LP gas, generator, appliances, and exterior) and gives you a detailed picture of the RV’s condition before you commit to buying.
For tips on what else to check during the buying process, see our guide to what to look for when buying a used camper.
A regular RV inspection routine can extend your RV’s lifespan, but breakdowns still happen. See our guide on what to do when your RV breaks down on the road and how mobile service can help.
When was the last time you had your RV inspected by a trained technician? Tell us in the comments below.
The post Where to Get Your RV Inspection appeared first on Camping World Blog.
This is a companion discussion topic for the original entry at https://blog.campingworld.com/learn-to-rv/where-to-get-your-rv-inspection/
