CAMPERS OFTEN ASSOCIATE RV generators with off-grid camping, but their advantages extend beyond boondocking. They also make it easy to pull over on a long road trip and fire up the generator to cool your RV down or microwave leftovers for lunch. And, in many scenarios, a quiet generator for camping ensures you don’t violate noise ordinances or upset your camp neighbors.
Let’s explore the best quiet generators for camping and why you might need one for your RV.
- Quiet generators are essential for comfortable RV camping — not just for boondocking, but also for quick roadside stops and respecting campground noise limits. A calm generator typically operates at or below 60 decibels, making inverter generators the preferred option due to their efficient and noise-reducing technology.
- Top quiet generators include the Honda EU2200i, Cummins Onan P4500iDF, Honda EU3200iAC, and Champion 5,500W Dual-Fuel. Each offers a balance of low noise output, fuel efficiency, and power capacity for various RV sizes and energy needs.
- You can make existing generators quieter by placing them on vibration-absorbing surfaces, using sound deflectors or enclosures, and positioning them strategically. Still, many campgrounds enforce strict noise limits, so investing in a quieter model or alternative power sources like solar may be necessary for overnight use.
What Defines a “Quiet” Camping Generator?
A “quiet” camping generator typically operates at or below 60 decibels (dB) from 23 feet away—the approximate volume of a normal conversation. For RV owners, a quieter generator reduces your risk of disturbing neighboring campers, violating campground noise restrictions, or disrupting your peace while enjoying nature.
Inverter generators are the quietest type due to their advanced sound-dampening and load-adjusting capabilities. When choosing a quiet generator for camping, prioritize decibel ratings, fuel efficiency, and the ability to run at low loads without ramping up noise.
Picks for the Best Quiet Generator for Camping
While your choice will largely depend on the size of the generator for your RV, compare our selections for the top-rated quiet generator for RV camping.
Honda EU2200i Portable Generator
- Decibel Rating: 48-57 dB
- Wattage: 2,200 max (1,800 rated)
- Runtime: Up to 8.1 hours
- Dimensions: 20” L x 11.4” W x 16.7” H
- Weight: 47.4 pounds
The Honda EU2200i is our pick for the best small quiet generator for camping. It strikes a balance between portability, performance, and ultra-quiet operation. With a whisper-quiet noise level of 48 dB at ¼ load up to 57 dB at rated load, it’s perfect for powering basic RV essentials without drawing attention.
At under 50 pounds, this small, quiet camping generator is easy to move around your site, store in a compartment, or load into your tow vehicle. Honda’s reputation for reliability and fuel efficiency makes this a go-to pick for campers who prioritize minimal noise, making it one of the quietest small generators for camping in an RV.
- Decibel Rating: 52 dB
- Wattage (Gas): 4,500 max (3,700 rated)
- Wattage (Propane): 4,050 max (3,330 rated)
- Runtime (Gas): Up to 12.5 hours
- Runtime (Propane): Up to 15 hours
- Dimensions: 25.5” L x 18.12” W x 20.5” H
- Weight: 105 pounds
Looking for the quietest dual-fuel generator for camping? The Cummins Onan P4500iDF is a standout. With a decibel rating of 52 dB and the flexibility to run on gas or propane, it delivers power and versatility without the roar of traditional generators. Whether you’re dry camping or just want to extend your power options, this RV generator lets you enjoy long run times (up to 15 hours on propane) with peace and quiet. The dual-fuel capability means you can carry less gasoline and switch to propane when needed—all without sacrificing low-noise performance.
Honda EU3200iAC 50-State Inverter Generator
- Decibel Rating: 54-58 dB
- Wattage: 3,200 max (2,600 rated)
- Runtime: Up to 8.6 hours
- Dimensions: 22.5” L x 12” W x 17.8” H
- Weight: 59.1 pounds
The Honda EU3200iAC is our top pick for the quietest inverter generator for camping in its wattage class, operating at 54 dB at ¼ load up to 58 dB at rated load. Honda’s inverter technology ensures clean, stable power that is ideal for sensitive RV electronics while maintaining ultra-quiet performance.
Weighing less than 60 pounds, it’s an excellent choice for RV campers seeking a Honda quiet camping generator with enough juice to power an air conditioner or microwave without waking the campground. With Bluetooth capability to control operation through Honda’s smartphone app and 50-state emissions certification, it’s one of the most advanced and environmentally-friendly Honda quiet generators.
Read our full Honda EU3200iAC review.
Champion 5,500W Dual-Fuel Generator
- Decibel Rating: 61 dB
- Wattage (Gas): 5,500 max (4,000 rated)
- Wattage (Propane): 5,000 max (3,600 rated)
- Runtime (Gas): Up to 14 hours
- Runtime (Propane): Up to 21 hours
- Dimensions: 24.6” L x 19” W x 20.9” H
- Weight: 121.4 pounds
Need more wattage for high-demand RVs? The Champion 5,500W Dual-Fuel Generator offers high power output and quiet operation for its size. With a decibel rating of just 61 dB—impressively quiet for a unit delivering up to 5,500 watts—this is an ideal large, quiet generator for camping in fifth wheels or toy haulers with multiple appliances. Its dual-fuel capability ensures longer runtime options, whether fueled by propane or gas. For RVers needing serious output without excessive noise, this generator delivers.
- Pulsar 2200W Dual-Fuel Generator – Lightweight, dual-fuel versatility with modest quiet performance.
- Cummins Onan P4500i – Similar to the iDF but gas-only.
- Honda EU3000iS 49-State – Super-quiet and powerful, but heavier than the EU2200i and EU3200i.
- Champion 2500W Inverter Generator – Ultra-portable inverter option for campers with minimal power needs.
- Cummins Onan P2500i – Compact and quiet for basic off-grid use.
Can You Quiet an Existing Generator for RV Camping?
Yes, there are several ways to reduce generator noise. If you’re wondering how to make a generator quiet for camping, start by placing it on a softer surface like a rubber mat to absorb vibrations. Building a sound deflector using plywood panels lined with insulation foam can significantly reduce output noise. If you’re wondering how to quiet a generator while camping, strategic placement is key: position the exhaust away from your RV and neighboring sites, and consider a generator box or enclosure with proper ventilation.
See why a generator cover or safe enclosure is a wise investment.
What’s an Acceptable Noise Level for an RV Generator?
Most campgrounds require generators to operate at or below 60 decibels at 50 feet. National parks and some quiet-hour rules are even stricter, making generators in the 48-55 dB range much more campground-friendly. If your generator sounds no louder than an everyday conversation, you’re likely within acceptable limits. But always check with the campground to ensure your generator won’t exceed their noise regulations.
Should You Run a Portable Generator All Night?
While some portable generators can technically run all night, it’s not advisable. Prolonged use can lead to overheating, faster wear, and elevated fuel costs. Many campgrounds also enforce generator quiet hours when generator use is prohibited—typically from 10 p.m. to 6 a.m. If overnight power is essential, such as for medical devices, consider portable battery banks or solar setups. Alternatively, choose a generator with an extended runtime and a low decibel rating to reduce disturbances.
Explore solar options for off-grid camping.
Explore these additional resources to find and maintain your perfect camping generator:
- What Size Generator for 30 Amp RV?
- What’s the Best RV 50 Amp Generator?
- How Long Do RV Generators Last?
- Tips for Portable Generator Safety
- What’s the Best RV Solar Generator?
What criteria do you look for in quiet generators for camping? Let us know in the comments below!
The post What’s The Best Quiet Generator for Camping in an RV? appeared first on Camping World Blog.
This is a companion discussion topic for the original entry at https://blog.campingworld.com/gear-and-accessories/best-quiet-generator-for-camping/
