The Best Half Ton Towable Toy Haulers
FINDING A HALF-TON TOWABLE toy hauler that your truck can safely and comfortably pull can be challenging. But manufacturers are designing more floor plans specifically built for half-ton towing, expanding your options. Most of these half-ton towable toy haulers are travel trailers with an excellent balance of hauling capability, comfortable living space, and RV amenities unique to the toy hauler class.
This guide will highlight some of the best half-ton towable toy hauler RVs and help you determine the best for your truck and camping needs.
  • Towing Basics & Weight Limits: A toy hauler is typically considered half-ton towable if it has a dry weight under 7,000 lbs and a GVWR under 9,000–10,000 lbs. However, always check your truck’s specific towing and payload ratings to ensure safety, especially when fully loaded with gear and water.
  • Top Brands & Floor Plans: Leading options for half-ton towable toy hauler travel trailers include the Forest River Nightfall, Cherokee Grey Wolf, Vengeance Rogue SUT, Cherokee Wolf Pack, and Momentum G-Class. These offer garage lengths up to 20’7”, sleep up to 7 people, and combine rugged cargo capability with modern RV comforts.
  • Choosing the Right Fit: While toy haulers are generally heavier than traditional travel trailers, many models now balance lightweight towability and utility. The Momentum G-Class 21G is a standout option under 12,000 lbs GVWR. For even lighter needs, small models like the Wolf Pup 18RJBW or No Boundaries offer ultra-light toy hauling for compact trucks or SUVs.
What Camper Weight is Half Ton Towable?
A camper is generally considered half-ton towable if its dry weight is under 7,000 pounds and its GVWR (fully loaded weight) stays below 9,000–10,000 pounds. However, the exact limit depends on your truck’s specific towing and payload capacities.
Modern half-ton trucks like the Ford F-150 or Ram 1500 can tow between 7,000 and 13,000 pounds, depending on their configuration. However, it’s essential to account for cargo, water, gear, tongue or pin weight, and the trailer’s dry weight. To stay safe and within limits, aim for a trailer well within your truck’s rated capabilities, and always check your vehicle’s towing and payload specs before you buy.
For this article, we’ve selected toy hauler brands with multiple floor plans that have GVWRs under 12,000 pounds and hitch or pin weights under 2,000 pounds, keeping them under the standard towing and payload capacities of popular half-ton trucks like the Ford F-150, Chevy Silverado 1500, and GMC Sierra 1500.
Top Half Ton Towable Toy Hauler Travel Trailer Brands
While toy hauler travel trailers offer serious hauling power and living space, finding one light enough for a half-ton truck can be tricky. Luckily, the top half-ton towable toy hauler travel trailer brands offer models that balance rugged garage space with manageable towing weights. Each boasts unique layouts, features, and garage configurations to fit your gear and lifestyle.
Nightfall
Want to see the latest RVs? Subscribe to the Camping World YouTube channel, and never miss a video.
Specs (for the select models)
  • Length: 26’11” to 33’4″
  • Dry Weight: 6,368 to 7,163 pounds
  • Cargo Capacity: 2,450 to 3,500 pounds
  • Garage Length: 11′ to 14’6”
The Forest River Nightfall toy hauler lineup is designed for weekend thrill-seekers and serious gear haulers. These toy hauler travel trailers feature durable aluminum construction, a one-piece PVC roof, and a fully enclosed underbelly, making them ready for extended-season camping. Wide-stance axles and an electric tongue jack make driving and setup smooth and stress-free.
Inside, you’ll find a clever mix of style and functionality. Residential-style kitchens feature seamless countertops and stainless steel sinks, while the garages double as living spaces with flip-up sofas, removable tables, and large windows that let in plenty of natural light.
Need privacy? Integrated blackout shades provide it. Plus, built-in USB charging ports and a Bluetooth audio system keep things convenient and connected.
Across the lineup, floor plans offer flexibility for different adventures. The Nightfall half-ton towable toy haulers with compact 11’ garages are perfect for smaller toys or gear-heavy travel, while others stretch the garage space to 14’6” to fit full-size ATVs or multiple bikes.
Sleeping arrangements vary, too. All floor plans include a drop-down bed and sofa sleepers in the garage. But you’ll find variety in the primary sleeping areas, including queen beds in slide-outs and Murphy beds. Whatever your setup, Nightfall haulers are ready to roll when you are.
Cherokee Grey Wolf
  • Length: 24’1” to 34’
  • Dry Weight: 4,463 to 6,738 pounds
  • Cargo Capacity: 2,142 to 3,247 pounds
  • Garage Length: 10’1” to 14’2”
The Cherokee Grey Wolf toy hauler lineup is built for adventure with five exciting half-ton towable RVs: the 18RR, 22RR, 24RRT, 25RRT, and 27RR. These trailers combine rugged construction, like powder-coated frames and enclosed underbellies, with innovative design touches such as outdoor LP quick connects, 15-foot power awnings with LED lighting, and tankless water heaters that make camp life more luxurious.
Inside, you’ll find a surprisingly stylish setup. Residential-style 12V refrigerators, seamless countertops, and versatile garage furniture give each model a polished yet practical vibe. The rear garages transform into living or dining spaces in a snap, thanks to fold-down sofas and removable tables. Oversized windows flood the space with natural light, while blackout shades let you wind down when it’s time to relax.
Each half-ton towable toy hauler offers something a little different. The compact 18RR has a 10’1” garage—perfect for hauling a couple of motorcycles—while the 27RR delivers more living space with a slide-out and a separate 11-foot garage.
Sleeping capacity varies across the lineup, with queen beds in smaller units and RV king beds in the larger ones. No matter which floor plan you choose, the Cherokee Grey Wolf lineup is ready to go where the action is.
Vengeance Rogue SUT
23SUT & 29SUT. Images by Forest River.
  • Length: 27’2” to 35’7”
  • Dry Weight: 5,498 to 7,738 pounds
  • Cargo Capacity: 3,837 to 4,4497 pounds
  • Garage Length: 10’6” to 20’
The Vengeance Rogue SUT series by Forest River is designed for thrill-seekers who need a rugged, half-ton towable toy hauler without sacrificing comfort. These models boast a 102″ wide-body design, providing spacious living quarters and ample gear storage. With durable construction and high-capacity axles, they’re built to handle the demands of wherever the road may take you.
Step inside and feel at home with a light-colored interior and a blend of functionality and style. Features include a 12V high-efficiency residential refrigerator, seamless countertops, and convertible garage furniture that effortlessly transitions from cargo space to living area. Large panoramic windows and blackout shades enhance the interior ambience, while tech upgrades like USB charging ports and a Bluetooth audio system keep you connected and entertained.
Each floor plan offers unique advantages. The 23SUT is compact yet spacious, featuring innovative design elements like a flip-up bed, which enables it to accommodate larger toys. The 25SUT balances garage space and living area, with a king-size bed and a 21-foot power awning for outdoor relaxation. The 29SUT steps it up with a slide-out for additional living space and seating for plenty of guests.
No matter which half-ton towable RV you choose, the Vengeance Rogue SUT lineup is ready to accompany your next adventure. It offers the perfect blend of utility and comfort for your on-the-go lifestyle.
Cherokee Wolf Pack
Wolf Pack 26-13.5. Images by Forest River.
  • Length: 29’7” to 37’11”
  • Dry Weight: 6,398 to 8,988 pounds
  • Cargo Capacity: 2,702 to 4,922 pounds
  • Garage Length: 12’6” to 14’5”
If you’re a couple with toys to haul and trails to conquer, the Cherokee Wolf Pack travel trailer toy haulers strike the perfect balance between rugged utility and cozy comfort. These RVs are engineered for durability without skimping on usability. A ramp door patio system and rear screen wall come standard—perfect for unwinding after a ride—while the MORryde® entry steps and outdoor shower add an extra layer of convenience.
Inside, each couple-friendly RV features a residential king bed, ample wardrobe space, and a clean, open layout. The garages double as flexible living areas or lounges, thanks to HappiJac™ power sofas that lift out of the way when unused. You’ll also find thoughtful upgrades like zebra shades for light control, real wood cabinet doors, and dual-zone stereo systems with indoor and outdoor speakers.
With three half-ton towable travel trailer floor plans, there’s a great fit for different hauling needs. The 24PACK14.5 offers the longest garage at 14’5″, ideal for large ATVs or a pair of bikes. The 25PACK14 balances garage length with living space, while the 27PACK12.5 includes a slide-out for extra elbow room. Across the board, these Wolf Pack toy haulers make it easy for couples to hit the road with all the necessary gear and comfort.
Momentum G-Class
Image by Grand Design
  • Length: 26’11 to 35’11
  • Dry Weight: 6,490 to 8,975 pounds
  • Cargo Capacity: 3,280 to 5,331 pounds
  • Garage Length: 11’ to 20’7”
With premium features in a half-ton towable package, the Momentum G-Class travel trailer toy haulers combine unexpected luxury with innovative utility. These toy hauler RVs are built with laminated aluminum sidewalls, a gelcoat fiberglass exterior, and a fully enclosed underbelly. Standard features like a fuel station, a versatile ramp door patio system, and an adjustable power awning make it easy to camp your way.
Inside, you’re greeted by a space that feels more like a high-end apartment than a camper. Each model includes residential finishes like solid surface countertops, stainless steel appliances, and plush seating arrangements. The garage easily transforms from a cargo zone to a lounge, thanks to HappiJac™ rollover sofas and a bed lift system. Thoughtful touches like LED accent lighting, Euro-style recliners, and large panoramic windows help the Momentum G-Class feel anything but basic.
If you’re looking for a half-ton towable toy hauler, the 21G is your best bet. It’s the only model in the lineup with a GVWR under 12,000 pounds, making it more accessible for many light-duty trucks. It offers a 14-foot garage and sleeps up to six, so you’re not giving up much space.
The other floor plans, including the 23G, 25G, and 29G, bump up to a 13,000-pound GVWR, which may exceed some half-ton towing limits. With dry weights under 9,800 pounds, even these larger toy haulers could still work for select half-ton trucks—just keep a close eye on your payload and towing capacities. Whether you’re hauling dirt bikes or kicking back with friends at the campsite, the Momentum G-Class lineup makes it easy to do in comfort and style.
Comparisons
Because many of these brands feature non-toy hauler travel trailers or heavier fifth wheel models, filtering by RV Type will speed up your search:
Used Half Ton Towable Fifth Wheel Comparisons
Half-ton towable fifth wheel toy haulers are few and far between, especially if you’re shopping for new models. But if you’re open to buying a used RV, these options combine manageable weight with versatile garage spaces at more budget-friendly prices.
What Is the Lightest Toy Hauler?
Perhaps surprisingly, the lightest toy haulers on the market weigh less than 2,000 pounds. The smallest models from brands like Wolf Pup Black Label and No Boundaries can be towed by standard or mid-size SUVs or compact trucks.
Are Toy Haulers Lighter Than Travel Trailers?
Generally, toy haulers are heavier than similarly sized travel trailers. This is primarily because they’re built with stronger frames, axles, and ramp doors to support the extra weight of ATVs, bikes, or other toys. However, toy hauler construction also provides much higher cargo capacities than travel trailers. This ability to load more cargo makes larger trucks the safest bet for towing toy hauler campers.
Choosing the right half-ton towable camper means balancing gear-hauling needs with towing limits. Thankfully, today’s market offers plenty of excellent options. Whether you’re after a compact toy hauler for quick weekend getaways or a larger, feature-packed RV for extended adventures, the top toy hauler brands provide layouts and capabilities to fit your lifestyle.
Continue your search with these additional resources:
Which half-ton towable camper are you taking out on your next adventure? Let us know in the comments below!
The post The Best Half Ton Towable Toy Haulers appeared first on Camping World Blog.
This is a companion discussion topic for the original entry at https://blog.campingworld.com/find-your-rv/best-half-ton-towable-toy-hauler/
