Mobile RV Repair Cost Guide: What to Expect
IF YOU’VE NEVER USED mobile RV repair before, the biggest question is probably the simplest one: What’s this going to cost? Unlike a routine oil change with a posted price, mobile RV repair costs depend on the type of repair, how far the technician has to travel, and whether the issue is fixed in one visit or requires follow-up. This guide breaks down exactly what goes into a mobile RV repair bill, typical price ranges by repair type, and how to make sure you’re never surprised by a quote.
How Mobile RV Repair Pricing Works
Most mobile RV repair costs break down into three separate line items. Learn how to read a quote accurately and compare providers.
1. Travel Fee (Trip Charge)
This covers the technician’s time and mileage to reach your location, whether that’s a campground, your driveway, or a storage facility. Travel fees are typically flat within a defined service radius and increase for locations farther from the technician’s home base.
Some mobile techs will charge a flat travel fee, while others charge by the mile. Some combine these fees, offering a flat rate for travel within a certain distance, followed by a per-mile charge for travel beyond that distance.
2. Diagnostic Fee
Many mobile RV technicians charge a diagnostic fee to assess the problem, separate from the repair itself. This fee may still apply even if you decide not to proceed with the repair. Some providers waive or credit the diagnostic fee toward the final repair cost if you proceed. Some mobile repair services will combine the travel and diagnostic fees into a single flat rate, while others will charge separate fees.
RV Pro Tip: Ask whether the diagnostic fee is credited toward the repair cost if you move forward. This is a common and reasonable practice, but it isn’t universal. Always confirm before the technician arrives.
3. Labor and Parts
This is the actual cost of fixing the problem. The technician’s hourly labor rate plus any parts required. Part costs vary by manufacturer and component availability. Some parts may need to be ordered, which can affect whether the repair can be completed in a single visit.
Mobile technician labor rates will ultimately depend on the technician’s certifications and your location. Seasonal changes and services during popular events can also result in higher rates.
RV Pro Tip: Take the time to get detailed estimates, shop around, and negotiate. And if you’re dealing with an active breakdown, start with our guide on what to do when your RV breaks down, which covers when to call mobile service vs roadside assistance.
What Does Camping World Mobile RV Service Cost?
Camping World offers mobile RV service at select locations nationwide. As with most mobile RV service providers, pricing depends on your location, the type of repair needed, and the time required to complete it. All charges, including any minimum diagnostic fee and travel charges,  should be explained in detail when you schedule your appointment.
Because availability and pricing structure can vary by location, the most accurate way to get a quote is to call your nearest Camping World and ask about mobile service in your area.
Typical Cost Ranges by Repair Type
Actual pricing always depends on your location, technician, and RV, but the ranges below reflect typical costs reported across the mobile RV repair industry. Use them to set expectations, but get a specific quote for your situation.
Air Conditioner Repair
Typical cost: $150-$1,200 for common repairs; full unit replacement runs $800-$1,500.
The most frequent AC failure is a run or start capacitor, which typically runs $220-$420 and is usually completed in a single visit. More involved issues push toward the higher end of the range, especially on older units, where a repair-vs-replace decision often makes more sense once labor rates exceed several hundred dollars.
Sources: Mobile RV Pro | JB RV | Micro-Air
Slide-Out Repair
Typical cost: $150-$5,000.
A simple adjustment or lubrication sits at the low end, while motor replacement typically runs $500-$1,200, and full mechanism or electrical overhauls can reach $1,000-$5,000. In-wall motor systems (like Schwintek) tend to run $485-$985 installed.
Structural repairs involving water damage or floor rot are the most expensive scenario and are the main reason costs can spike. Catching a seal or alignment issue early keeps most slide-out repairs on the lower end of the range.
Sources: Mobile RV Pro | A1 RV Repair | RV Upgrade Store | JB RV
Generator Repair
Typical diagnostic fee: $137-$450, plus parts and labor.
Common fixes are usually resolved in a single mobile visit at a modest total cost, while more involved internal repairs run higher and may require the generator to be removed for shop-level work.
Sources: RCS Electrical Services | Wizard Group
Water Heater Repair
Typical cost: $100-$1,000+.
Small parts like a thermostat ($40-$80), heating element ($30-$60), or anode rod (around $12) are inexpensive and quick to install (sometimes in the same visit as the diagnostic). Full water heater replacement is the higher end of the range, particularly for tankless upgrades that involve additional gas line work.
Labor alone for a basic tank swap typically runs $200-$400, while a tankless installation can run $600-$800 in labor. If your RV is under 5 years old, check your manufacturer’s warranty before paying out of pocket. Some brands cover water heater failures during that window.
Sources: AA Mobile RV Repair | Solar RV Tipes
Plumbing Repair
A straightforward leak repair often costs around $100, since most plumbing components don’t require special ordering. More involved plumbing work, or repairs that uncover secondary water damage, can push costs well past $1,000. Plumbing issues are generally one of the more affordable and fastest categories for a mobile technician to resolve in a single visit.
Source: AA Mobile RV Repair
Electrical Repair
Typical cost: Ranges from included in the base labor charge to $2,500+ for larger repairs.
Diagnostic time can run longer for electrical issues since a technician needs to trace the problem through your RV’s wiring, but many common issues are identified and fixed quickly once the source is found.
RV Pro Tip: If your RV is still under manufacturer warranty, some of these repairs may be covered. Contact your manufacturer before scheduling a paid mobile repair to confirm whether the issue is covered under warranty and to ask whether Camping World is an authorized service provider for your brand.
All figures above are third-party industry estimates gathered from multiple mobile RV repair providers and are provided for general budgeting purposes only. They do not represent Camping World mobile service pricing. Contact your nearest Camping World location for an exact quote.
Mobile RV Repair vs Taking Your RV to a Shop
Cost is often the deciding factor between mobile repair and a shop visit. Here’s how the two compare:
Mobile RV repair tends to cost less overall when:
  • The issue is in the living quarters (appliances, plumbing, electrical, slide-outs) and doesn’t require specialized shop equipment
  • Towing would otherwise be required to reach a shop
  • A shop visit means sitting in a repair queue, adding storage and downtime costs, as well as possible living expenses if the RV is your living quarters
  • You want to avoid the inconvenience of relocating your RV and belongings during the repair
A shop visit tends to be the better value when:
  • The repair requires specialized equipment (lifts, alignment tools, clean-room conditions)
  • Multiple systems need diagnosis, and one facility can assess everything at once
  • The work is under warranty and needs manufacturer-authorized documentation
  • Parts need to be ordered, and the RV can be safely left at the shop while you wait
In many cases, a hybrid approach makes sense: a mobile technician handles what can be fixed on-site, while anything requiring a more detailed RV inspection with shop equipment gets scheduled separately.
Learn more about what repairs require an RV service center.
Is Mobile RV Repair Worth It?
When the alternative is towing costs, lost travel time, or being displaced from their RV, mobile repair outweighs the cost. You are paying for the convenience and expertise of a certified technician who comes to you.
The calculation changes if your issue requires shop-level equipment or extensive parts ordering. In those cases, a mobile technician’s diagnostic visit still has value for accurately identifying the problem before you commit to towing or scheduling shop time.
Technician Tip: The mobile tech’s diagnosis is a valuable reference when shopping for the best in-shop repair deal. It’s also useful for confirming an in-shop diagnosis or getting a second opinion.
How To Avoid Surprise Repair Costs
Ask for a written estimate before work begins. A reputable mobile RV technician will explain diagnostic fees, travel charges, and expected labor costs upfront.
Ask what happens if the repair can’t be completed on-site. Clarify whether you’ll still owe the diagnostic and travel fee even if the issue requires a shop visit.
Confirm parts availability before scheduling. If a part needs to be ordered, ask how that affects the total cost and timeline.
Check your warranty or service contract status first. If your RV is still covered, some repairs may cost significantly less — or nothing at all — through a manufacturer-authorized service center.
Check for factory-paid recalls or service bulletins. These may pay for the necessary repairs. Verify whether the work can be done by a mobile tech or whether the RV must be at an authorized service center to be covered.
Ask about travel radius pricing. If you’re at a remote campsite, confirm whether your location falls within the standard travel fee range or incurs an extended-distance charge.
How much do mobile mechanics charge per hour?
Mobile mechanic and RV technician hourly rates vary by region and specialization and are generally comparable to, or somewhat higher than, standard in-shop labor rates, reflecting the convenience of on-site service. Ask for the specific hourly rate and any minimum labor charge before scheduling.
Does Camping World charge a fee for mobile RV service?
Camping World’s mobile RV service fees vary by location and the type of repair needed. All charges, including any minimum diagnostic fee and travel costs, are explained in detail when you schedule your appointment. Contact your nearest Camping World location to confirm mobile service availability and get a specific quote for your area.
Are mobile RV repairs more expensive than shop repairs?
Not necessarily. For repairs that can be completed in a single on-site visit, mobile service is often comparable in total cost to a shop repair once towing fees and shop queue time are factored in. The travel fee is usually the only additional line item — and it’s frequently offset by what you’d otherwise pay to move the RV.
More Resources:
Have you used mobile RV repair before? Share what you paid and what the experience was like in the comments below — it might help a fellow RVer know what to expect.
The post Mobile RV Repair Cost Guide: What to Expect appeared first on Camping World Blog.
This is a companion discussion topic for the original entry at https://blog.campingworld.com/learn-to-rv/mobile-rv-repair-cost/
