3 Best Roof Reseal Kits for RVs
Resealing your RV roof is a crucial maintenance task to prevent leaks and moisture damage. But with various roof reseal kits on the market, each with different materials, coverage, and durability, how do you pick the right one? Price is certainly a factor, but it’s not the only consideration. You’ll want a kit that’s compatible with your specific roof material. Ease of application also matters – some kits are more beginner-friendly than others. And then there’s the question of how long the sealant will last under harsh weather conditions and UV exposure. To save you hours of research, we have picked the best three roof reseal kits that rank high in quality.
Roof Reseal Kits Comparison Table
Here’s a head-to-head comparison of our top 3 roof reseal kits:
Brand Liquid Rubber RV Roof Coating TPO RV Rubber Roof Kit RecPro Extreme Duty RV Camper Rubber Roof Kit
Price $500-$550 for a 5-gallon kit $450-$600 for a 30-foot kit $600-$650 for a 30-foot kit
Weight 40 lbs 150 lbs 135 lbs
Durability Withstands extreme temperatures, guaranteed leak-free Puncture-resistant, UV-resistant, flexible Highest tensile strength, tear & puncture-resistant, weatherproof
Coverage 50 sq ft/gallon 160-200 sq ft/gallon 160-200 sq ft/gallon
Roof Compatibility EPDM, TPO, aluminum, fiberglass TPO, EPDM, PVC PVC synthetic rubber, TPO, EPDM
Accessories Included Seam tape, lap sealant (sold separately) TPO material, sealant, butyl tape, adhesive PVC material, sealant, butyl tape, adhesive
Warranty 10-year warranty Not available 15-year non-prorated warranty
1. Liquid Rubber RV Roof Coating: Best Roof Reseal Kit for Multiple Roof Types
We earn a commission if you make a purchase, at no additional cost to you.
04/22/2025 11:22 pm GMT
Price:
  • $500 – $550
Features:
This liquid rubber coating flows into cracks and crevices, creating a seamless waterproof seal on various roof types including EPDM, TPO, aluminum, and fiberglass. It’s easy to apply, even for beginners. Some of its key features include:
  • Elastomeric and UV-resistant.
  • Brilliant white color reflects the sun for a cooler interior.
  • Seam tape and lap sealant are available for complete waterproofing.
  • Primer may be required depending on the roof type.
Pros:
  • Versatility: Compatible with most common RV roof materials.
  • Durability: Withstands extreme temperatures; remains flexible.
  • Leak-Free: Adheres through expansion and contraction.
  • Heat Reduction: Solar reflective properties keep RV cooler.
Cons:
  • Cure Time: Takes 24-48 hours to fully cure.
  • Possible Extra Step: Certain roof types require a primer before coating.
2. TPO RV Rubber Roof Kit: Most Durable Roof Reseal Kit
04/22/2025 11:25 pm GMT
Price:
  • $450 – $600
Features:
Made of puncture and UV-resistant thermoplastic polyolefin (TPO), this kit is built to last in harsh weather conditions. It comes with all installation components like sealant, butyl tape, and adhesive. The TPO material is flexible enough for sloped roofs, chemical-resistant, low-maintenance and available in various sizes.
Pros:
  • Long-Lasting: Highly resistant to punctures, UV and chemicals.
  • All-Inclusive: Comes with all necessary installation accessories.
  • Large Coverage: Covers 160-200 sq ft/gallon.
Cons:
  • Heavy: Weighs around 150 lbs; may need assistance to move.
  • Potential Learning Curve: May require specialized tools and techniques for proper installation.
3. RecPro Extreme Duty RV Camper Rubber Roof Kit: Best Value Roof Reseal Kit
04/22/2025 11:27 pm GMT
Price:
  • $600 – $650
Features:
This kit uses durable PVC synthetic rubber that’s anti-microbial, reflective, and maintenance-free. Each kit includes PVC roofing, sealant, butyl tape, and adhesive.
Its standout qualities include:
  • Highest tensile strength.
  • Tear and puncture-resistant.
  • Weatherproof.
  • Fast-drying adhesive for quick installation.
  • Multiple size options from 5′ to 40′.
Pros:
  • Strong Material: Offers superior strength and weather resistance.
  • Budget-Friendly: Lower price point than many competitors.
  • Straightforward Installation: Includes all supplies; adhesive dries quickly.
  • Excellent Warranty: Backed by a 15-year non-prorated warranty.
Cons:
  • Some DIY Skill Required: May be challenging for beginners to use.
How We Picked the Top Roof Reseal Kits
With so many roof reseal kits available, how did we narrow it down to three standout products? Here are the key factors we evaluated:
  • Material Quality: We looked for kits using high-performance, durable materials like EPDM, TPO, and PVC that can withstand harsh UV rays, extreme temperatures, and punctures.
  • Ease of Installation: While some DIY skill is expected, we prioritized kits that include all necessary supplies and accessories, provide clear instructions, and don’t require overly specialized tools.
  • Leak Protection: The best kits form a waterproof, flexible seal that resists cracking and peeling over time, with good adhesion to the roof surface.
  • Roof Compatibility: We aimed to include kits that work with the most common RV roof types — EPDM, TPO, fiberglass, and aluminum.
Get the Right Roof Reseal Kit for Your RV
Choosing the right roof reseal kit comes down to your RV’s specific needs. If multi-material compatibility, easy application, maximum durability, and industrial-strength leak protection are your priorities, these roof reseal kits offer all of them.
Whichever kit you choose, proper surface preparation is key. Make sure to thoroughly clean, dry, and if needed, prime your RV roof before applying any sealant. And don’t forget regular inspections and touch-ups to keep your roof in leak-free condition for years to come. For more expert tips, check out our guide on how to repair RV roofs.
The post 3 Best Roof Reseal Kits for RVs appeared first on RVshare.
This is a companion discussion topic for the original entry at https://rvshare.com/blog/compare-top-roof-reseal-kits-rvs/
