Water Heater Connection Leak Repair & Routine Maintenance
Today, I decided to tackle some plumbing maintenance on my RV, specifically focusing on a leak I noticed around my water heater connections. Over the last few weeks, I’ve seen some weeping where the plastic meets the metal on both the hot and cold connections. This issue became apparent because I mostly boondock, using my ...
This is a companion discussion topic for the original entry at https://www.loveyourrv.com/water-heater-connection-leak-repair-routine-maintenance/
