Find The Best RV Solar Generator
AN ALTERNATIVE POWER SOURCE is essential for extending camping trips. While traditional generators and battery power stations are common, they have drawbacks compared to RV solar generators.
Gas or propane-powered generators produce noise and emissions and require fuel storage. Portable power stations typically need recharging from an AC outlet and often lack the capacity for larger RV appliances. Meanwhile, solar generators provide quiet, emission-free power at a higher wattage rating and can recharge directly from sunlight instead of relying on LP or gas.
Many RVers will use a combination of these portable power sources, so let’s explore if a portable solar power generator is a worthy addition to your camping checklist.
  • RV solar generators provide quiet, eco-friendly power for camping and are ideal for recharging electronics and running small to mid-size appliances without noise, fumes, or fuel dependency.
  • Top solar generator picks vary by use case, from budget-friendly and compact models like the ACOPOWER and EcoFlow River 2 to high-capacity options like the EcoFlow DELTA Pro that can power entire RV systems.
  • Compared to inverter generators, solar generators offer clean operation with minimal maintenance. However, inverter generators remain better suited for high-wattage demands like air conditioning, making a hybrid power setup ideal for most RVers.
What Is a Solar Generator?
A solar generator is a portable power system that uses solar panels to charge a battery, which then supplies electricity through built-in A/C outlets, DC ports, or USB connections. It typically includes four main components: solar panels, a battery, a charge controller, and an inverter.
For RVers, solar generators offer a quiet, eco-friendly alternative to gas-powered generators. They allow for off-grid camping without fumes or fuel costs.
Best Solar Generators for RV Camping
Let’s explore the best solar-powered generators ranked by most affordable, longest-lasting, best for small campers, and most compact for sensitive electronics.
Most Affordable: ACOPOWER 154Wh Solar Generator
Generator Specs
  • A/C Output: 500 watts (800W surge)
  • Capacity: 154 watt hours
  • Cycle Life: 1200 cycles to 80% capacity
  • Dimensions: 9.2” x 3.5” x 3.5”
  • Weight: 3.97 pounds
Solar Panel Specs
  • Rated Power: 50 watts
  • Folded Size: 14.2” x 11.4” x 2.4”
  • Unfolded Size: 53.1” x 14” x 0.16”
  • Weight: ~6 pounds
The ACOPOWER Solar Generator is a lightweight, affordable entry-level solution for powering essentials on weekend RV getaways. It’s best for charging small electronics like phones, tablets, LED lights, and cameras. The compact, foldable solar panel makes storing it in smaller campers or van conversions easy, and its low weight certainly won’t strain your cargo limits. This system is ideal for minimalist campers prioritizing portability and cost-effectiveness over high-capacity power output.
Longest Lasting: EcoFlow DELTA Pro with 400W Solar Panel
Generator Specs
  • A/C Output: 3,600 watts (7,200W surge)
  • Capacity: 3,600 watt hours
  • Cycle Life: 3,500 cycles to 80% capacity
  • Dimensions: 25” x 11.2” x 16.4”
  • Weight: 99 pounds
Solar Panel Specs
  • Rated Power: 400 watts
  • Efficiency: 22-40%
  • Dimensions: 42” x 94.1” x 1”
  • Weight: 35.3 pounds (~42 lbs with kickstand case)
The EcoFlow DELTA Pro is a powerhouse designed for serious off-grid RVers. It can power large RV appliances like air conditioners, microwaves, and electric cooktops. Its lifespan sets it apart, making it one of the most durable solar generators on the market. Pairing it with a high-efficiency solar panel means you can recharge quickly during peak sunlight hours—perfect for extended boondocking or full-time RV living.
Best for Small Campers: LION Energy Safari ME
Generator Specs
  • A/C Output: 2,000 watts (4,000W surge)
  • Capacity: 922 watt hours
  • Cycle Life: 2,500 cycles
  • Dimensions: 18.7” x 12.8” x 12.8”
  • Weight: 45.5 pounds
Solar Panel Specs
  • Rated Power: 100 watts
  • Folded Size: 26.5” x 20” x 2”
  • Unfolded Size: 26.5” x 40” x 1”
  • Weight: 22 pounds
The LION Energy Safari ME strikes a solid balance between portability and power. It can run mid-sized RV appliances and tools, and the 100-watt, 24V solar panel (sold separately) is efficient and compatible with expansion, offering faster charging than traditional 12V panels. It’s an excellent choice for small travel trailers, pop-ups, and teardrop campers that need a reliable but not oversized power solution.
Most Compact for Sensitive Electronics: EcoFlow River 2 with 110W Solar Panel
Generator Specs
  • A/C Output: 300 watts (600W surge)
  • Capacity: 256 watt hours
  • Cycle Life: 3,000 cycles to 80% capacity
  • Dimensions: 9.6” x 8.5” x 5.7”
  • Weight: 7.7 pounds
Solar Panel Specs
  • Rated Power: 110 watts
  • Efficiency: 22-23%
  • Folded Size: 20.2” x 16.5” x 0.8”
  • Unfolded Size: 20.2” x 62.5” x 0.8”
  • Weight: 8.8 pounds
The EcoFlow River 2 is one of the lightest solar generators built for RV travelers. Despite its compact size, it delivers clean, stable power ideal for laptops, CPAP machines, drones, and other sensitive electronics. Though it offers a modest output, it recharges quickly and includes a high-efficiency, foldable solar panel. This generator is perfect for weekend trips, tent camping, or as a backup battery for digital nomads working from the road.
EcoFlow Solar Generator Comparisons
Comparing the Best Solar Generators
Compare all the models highlighted above, starting with A/C output, capacity, and cycle life:
ModelA/C OutputCapacity (Wh)Cycle Life
ACOPOWER 154Wh500W (800W surge)1541200
EcoFlow River 2300W (600W surge)2563,000
LION Safari ME2,000W (4,000W surge)9222,500
EcoFlow River 2 Pro800W (1,600W surge)7683,000
EcoFlow DELTA 21,800W (2,700W surge)1,0243,000
EcoFlow DELTA Max 20002,400W (5,000W surge)2,016800
EcoFlow DELTA Pro3,600W (7,200W surge)3,6003,500
Now let’s highlight the differences in weight, solar panel wattage, and best use:
ModelWeightSolar Panel PowerBest Use
ACOPOWER 154Wh3.97 lbs50WBudget/Emergencies
EcoFlow River 27.7 lbs110WLaptops/CPAP
LION Safari ME45.5 lbs100WSmall Campers
EcoFlow River 2 Pro17.2 lbs220WLight RV Use
EcoFlow DELTA 227 lbs220WMedium Campers
EcoFlow DELTA Max 200048 lbs400WExtended Boondocking
EcoFlow DELTA Pro99 lbs400WWhole RV Power
Solar Generator vs Inverter Generator
Many campers struggle to decide between a solar generator and an inverter generator.
A solar generator consists of a battery bank, an inverter, a charge controller, and one or more solar panels. The system converts sunlight into electrical power, which is stored in the battery and later used to power devices and appliances. Because no fuel is burned, solar generators operate silently and emit no exhaust — a considerable advantage in quiet campgrounds and national parks.
An inverter generator, on the other hand, runs on gasoline or propane and produces A/C power through an internal combustion engine coupled with an inverter. It offers continuous, reliable power at higher wattage levels, making it well-suited for running energy-hungry RV systems like air conditioners.
Key Differences
FeatureSolar GeneratorInverter Generator
Noise LevelSilentModerate (50-70 dB)
FuelSolar-poweredGasoline or propane
MaintenanceMinimalRegular oil/filter changes
EmissionsNoneCO2 and fumes
Power OutputLower overallHigher for large loads
CostHigher upfrontLower upfront
Suitability for Different RV Lifestyles
Solar generators excel for campers who prioritize quiet, eco-friendly operation. They’re ideal for powering electronics like phones, laptops, lights, and CPAP machines, and they allow RVers to camp in sensitive areas where fuel generators may be restricted. With no ongoing fuel costs, solar generators can also pay off for full-timers who frequently boondock. Solar generators are unmatched for quiet, clean power during daytime use and overnight device charging.
Inverter generators shine when you need robust power on demand. A fuel-powered inverter generator will likely be more practical if you plan to run your RV air conditioner, microwave, or other high-wattage appliances for extended periods. They also recharge instantly with a full gas tank, whereas solar generators depend on available sunlight. For high-wattage, whole-RV backup, an inverter generator remains the more versatile choice, especially in poor weather or heavily shaded camping locations.
Many RVers employ a hybrid approach: using a solar generator for everyday power and keeping an inverter generator on hand for backup or air conditioner use. This gives you the flexibility to enjoy the best of both worlds.
Compare inverter generators vs regular generators.
Can I Run My RV AC With a Solar Generator?
Only a high-capacity solar generator like the EcoFlow DELTA Max or DELTA Pro can run average RV air conditioners. Running a 13,500 BTU RV air conditioner typically requires 2,500-3,00 surge watts and 1,300 to 1,500 running watts. A larger air conditioner will pull more power when starting up and running.
Look for a generator with at least a 2,000-watt-hour capacity and a surge rating above 3,000 watts. Even then, sustained air conditioner use will drain batteries quickly unless paired with high-output solar panels and optimal sun exposure.
Discover more about RV AC wattage demands.
What Size Solar Generator Do I Need for My RV?
In addition to choosing a solar generator with the correct output to run your air conditioner, you’ll also need to look at capacity to ensure you have enough stored power to meet your needs. Here’s a quick guide:
  • Weekend Warriors (Phones, Lights, Fans): 150Wh–500Wh
  • Digital Nomads (Laptops, Routers, Small Appliances): 500Wh–1,000Wh
  • Full-Timers (Fridge, Microwave, Coffee Maker): 1,000Wh–2,000Wh
  • Whole RV Backup (AC, TVs, etc.): 2,000Wh+
Calculate your needs by adding the wattage of all devices you want to run, then multiply by the hours of daily use to get your Wh/day estimate.
Learn more about choosing a generator for your RV.
Explore these additional resources to find the right generator and solar accessories for your camper:
Which solar generator for RV use would you choose? Let us know in the comments below.
The post Find The Best RV Solar Generator appeared first on Camping World Blog.
This is a companion discussion topic for the original entry at https://blog.campingworld.com/gear-and-accessories/best-rv-solar-generator/
