When you’re RVing or camping off-grid, a reliable portable power station is essential to keep your devices and appliances running. But with so many portable battery packs on the market, it can be tricky to know which one best fits your power needs, budget, and portability preferences.
After thoroughly researching various top portable battery packs, we’ve narrowed it down to 5 standout options. Our picks range from ultra-high-capacity units that can power your entire RV to compact, budget-friendly models for charging devices on the go. We’ll walk you through the key specs, features, pros, and cons of each portable battery pack, so you can find the perfect match for your RV setup and outdoor adventures.
Portable Battery Packs Comparison Table
Here’s a quick head-to-head comparison of our picks of the 5 best portable battery packs.
Model | Jackery Explorer 2000 Plus | EcoFlow DELTA Pro Ultra | EcoFlow RIVER 2 Max | Anker 757 PowerHouse | Bluetti AC70 |
Product image | |||||
Price | $1,299 – $4,299 | $4,999 – $7,999 | S469 – $499 (after discount) | $699 to $1,499 | $379 (on sale) |
Weight | 61.5 lbs | 70 lbs (6kWh unit) | 13.2-13.4 lbs | 43.9 lbs | 22.5 lbs |
Material | LFP batteries; durable materials | LFP batteries; aluminium & durable materials | LFP batteries | LFP batteries; aluminium alloy frame | Plastic casing; LFP batteries |
Durability | Built-in cooling; shock & fire resistant | IP54 rating; wide temp range; advanced cooling | TÜV certified; 3000+ charge cycles | Rugged, impact-resistant design | 3000+ charge cycles |
Dimensions | 14.1″ x 18.6″ x 14.7″ | 27.2″ x 18.9″ x 8.4″ | 10.6″ x 10.2″ x 7.7″ | 18.2″ x 11.3″ x 9.3″ | 12.4″ x 8.2″ x 10.1″ |
Warranty | 5 years battery; 3 years other components | 5 years | 5 years | 5 years | 5 years |
Capacity | 2042.8 Wh | 6kWh – 90kWh | 512 Wh | 1229 Wh | 716 Wh |
Output | 3000W rated, 6000W surge | 7.2kW – 21.6kW | 500W rated, 1000W surge | 1500W rated, 2400W surge | 700W rated, 1400W surge |
Ports | AC, DC, USB, more | 120V/240V, 30A | 2 USB-C, 2 USB-A, 2 AC, 1 car | 6 AC, 4 USB-A, 2 USB-C, 1 car | 2 AC, 2 USB-A, 1 USB-C, 1 car, 2 DC |
Charging | AC, solar, car | AC, solar, gas, EV charging | AC, solar, car, USB-C | AC, solar, car | AC, solar, car |
1. Jackery Explorer 2000 Plus: Our Best High-Capacity Pick
Price
$1,299 – $4,299.
Features
- Powers Heavy-load Devices too: The Jackery Explorer 2000 Plus boasts an impressive 2042.8 Wh capacity and 3000W rated output (6000W surge) to power even heavy-load devices like RV air conditioners.
- Multiple Charging Options: It offers multiple charging options, including ultra-fast charging from 0-100% in just 2 hours via AC adapter or 6 SolarSaga 200W solar panels.
- Expandable Capacity: Has an expandable capacity of up to 12kWh, parallel connection for up to 24kWh and 6000W output,
- Safe to Use: It has a built-in cooling system, shock and fire resistance, and an array of output ports (AC, DC, USB, and more).
- Ease of Transportation: The unit has built-in wheels and a handle for easier transport.
Pros
- High Capacity and Output: Powers heavy-load devices like RV air conditioners.
- Fast AC and Solar Charging: 0-100% in 2 hours.
- Quiet and Durable: Offers quiet operation which is as low as 30 dB.
- Versatile Outputs: Wide range of port options.
Cons
- Heavy: 61.5 lbs weight reduces portability.
- Higher Price: More expensive than lower-capacity models.
2. EcoFlow DELTA Pro Ultra: Top Whole-Home Backup Power
Price
$4,999 to $7,999+ based on configurations.
Features
- Flexible Usage: It is a modular, stackable system, and offers unparalleled flexibility. Capacity ranges from 6kWh to 90kWh, with 7.2kW to 21.6kW output depending on configuration.
- Fast Charging: The unit boasts lightning-fast charging, going from 0-80% in just 45 minutes with 6000W X-Stream tech.
- Dependable Usage: The LFP batteries provide 3,500+ cycles and a 10-year lifespan. The DELTA Pro Ultra also features a 20ms UPS reaction time, 16.8kW max solar input, and a unique X-Cooling Heat Dissipation System. An IP54 rating and wide operating temp range (-4 to 113°F) allow use in harsh conditions.
- Remote Monitoring: Users can easily monitor and control the unit remotely via the EcoFlow app.
Pros
- Massive Capacity and Output: Up to 90kWh and 21.6kW.
- Expandable and Stackable: Easily add more units.
- Fast Charging: 0-80% in 45 min; 16.8kW solar input.
- Durable: IP54 rating; wide operating temp range.
- Long Lifespan: 3,500+ cycles; 10 years.
Cons
- High Cost: The base model is more expensive as compared to other portable battery packs.
- Heavy: The inverter weighs 70 lbs and the battery weighs 116.4 lbs
- Large Size: Bulky dimensions. Inverter dimensions are 27.2 × 18.9 × 8.4 in and battery dimensions are 26 × 18 × 8 in.
3. EcoFlow RIVER 2 Max: Best Lightweight Option
Price
S469 – $499
Features
- Lightweight: Weighing just 13.2-13.4 lbs, the EcoFlow RIVER 2 Max provides an impressive 512Wh capacity and 500W output (1000W surge) in a compact, portable package.
- Easy Charging: It features X-Stream fast charging tech for a full charge in just 60 minutes and supports solar, car, and USB-C charging.
- Good Battery Life: The unit packs a long-lasting LFP battery with 3000+ cycles and a 10-year lifespan.
- Wireless Controls: You can control and monitor the unit via Bluetooth or Wi-Fi using the EcoFlow app. Safety features include a smart BMS and auto-off outlets when not in use.
Pros
- Portable: Weighs only 13.2-13.4 lbs and is easy to carry.
- Fast Charging: Charges from 0-100% in 60 minutes.
- App Control: Can be monitored and controlled via phone.
- Multiple Outputs: It offers multiple outputs, including 2 USB-C ports (one 100W), 2 USB-A, 2 AC outlets, and a carport.
Cons
- Limited Capacity: 512Wh capacity may not run larger appliances.
- Noise: Noise levels can reach 62dB under high loads.
- No Solar Panel: It is not available in the pack, and needs to be purchased separately.
4. Anker 757 PowerHouse: Most Versatile Battery Pack
Price
$699 – $1,499
Features
- Suitable Capacity: The Anker 757 PowerHouse delivers 1229Wh capacity and 1500W output (2400W surge) in a rugged yet reasonably portable design.
- Multiple Output Ports: With 13 output ports, including 6 AC outlets, 4 USB-A, 2 USB-C (one 100W), and a carport, it can charge a wide array of devices simultaneously.
- Informative LCD Display: An integrated LED light bar offers illumination, while the informative LCD shows real-time power stats.
- Thorough and Fast Charging: The 757 PowerHouse features pass-through charging, a power-saving mode, and supports solar input up to 300W. Fast charging allows the unit to reach 80% in just 1 hour and 100% in 1.5 hours.
Pros
- Fast Charging: 0-80% in 1 hour
- Long Lifespan: The LFP battery provides a 10-year lifespan and 3000+ cycles.
- Rugged Build: Is durably built for outdoor use.
- Useful Extras: Has an LED light bar and an LCD.
Cons
- Heavy: Heavier than some other models at 43.9 lbs weight. It is also bulkier as compared to some other products.
- Display Auto-Dims: This can make it inconvenient for usage.
5. Bluetti AC70: Best Value Pick
Price
$379
Features
- Excellent Value: The Bluetti AC70 offers an excellent balance of capacity, output, and price. Its 716Wh LFP battery provides 700W rated output (1400W surge) and 3000+ charge cycles.
- Offers 7 Output Ports: With 7 output ports — including a 100W USB-C PD, 2 USB-A, 2 AC outlets, a car port, and 2 DC barrel ports — it can power a variety of electronics.
- Offers Fast and Multiple Charging: The unit supports fast AC charging (0-80% in 1.8 hours), solar input up to 200W, and car charging.
- Smart Display and Portability: An intuitive LCD display shows real-time power stats. At just 22.5 lbs and compact dimensions, it’s highly portable.
Pros
- Quiet and Powerful: Offers quiet operations at <50db noise.
- 3000+ Battery Cycles: Has a long lifespan and offers fast charging
- Remote Controlable: Along with a smart touchscreen display, it can be controlled remotely via an app.
- 5-Year Warranty: Extensive coverage.
Cons
- Plastic Casing: Less durable than metal.
- Moderate Capacity: 716Wh suits small/medium devices.
- No App Control: Unlike EcoFlow models.
How We Selected the Top Portable Battery Packs
While choosing the top portable battery packs for your RV travels, we kept the following features in mind.
- Battery Capacity: Higher Wh ratings generally enable longer runtimes and more device charges. We looked for packs with at least 500Wh, ranging up to whole-home backup territory.
- Output Power: Packs should offer enough AC and DC output to run common camping gadgets and appliances. We prioritized models with 1000W or higher output and the ability to support surges.
- Portability: The ideal pack balances ample capacity with reasonable size and weight for transport. We considered packs under 30 lbs as highly portable but also included larger options for more power.
- Charging Speed: Faster charging, especially when relying on limited daytime sunlight, is a major convenience. We gave extra points to models that charge in under 2 hours.
- Durability and Lifespan: Outdoor use requires rugged construction and batteries that hold up over time. Our picks thus featured protective designs and long-lasting LiFePO4 cells.
- Extra Features: Value-adding extras like app control, expansion ports for chaining units, LED lighting, and UPS functionality helped models stand out from the pack.
Power Your Adventures With the Right Portable Battery Pack
The best portable battery packs for RV camping combine ample capacity and output with convenient features in a package that’s durable enough for outdoor use. Whether you prioritize expandability, lightning-fast charging, or raw power, our top picks offer strong options for a range of needs and budgets.
Remember to consider your typical power consumption and activities when selecting a battery capacity and output rating. If possible, opt for a pack with multiple charging options, especially solar, for flexibility on the road. And don’t forget to bring along any necessary cables and accessories.
For more expert tips on enhancing your RV experience, check out our guide to “Must-Have Affordable Camping Gear Basics“.
The post Best Portable Battery Packs for RVing: Our Top 5 Picks appeared first on RVshare.
This is a companion discussion topic for the original entry at https://rvshare.com/blog/top-rated-portable-battery-packs-best-options-compared/
